Re: 300 fouls plugs
Posted by Bob M on December 27, 2000 at 17:09:15 from (172.144.61.230):
In Reply to: 300 fouls plugs posted by Ron on December 27, 2000 at 16:37:39:
Ron - If you've not already done so, replace the plugs with D-21's (or D-23's if you can find them). Also check your carb idle mixture adjustment; it sounds like it's set too rich. (Too rich will show some black in the exhaust at idle and will foul the plugs - the two middle ones first.) Lean the mixture by turning the idle mix needle counterclockwise until you find the spot the engine idles fastest. Then slow it back down if required with the idle speed screw.
Post A Followup
: Re: Re: 300 fouls plugs
Today's Featured Article - Talk of the Town: Removin Broken Bolts - by Staff. Another great discussion from the Tool Talk Discussion Forum. The discussion started out with the following post: " How would I remove a bolt thats broken off in a piece of metal and I want to save the treads in the metal and then put in a new bolt. " ... [Read Article]
