Re: farmall f-20
Posted by FarmallGuy1923 on June 01, 2014 at 20:36:59 from (199.116.196.140):
In Reply to: farmall f-20 posted by farmall regular on May 30, 2014 at 18:21:25:
You might have a regular if it is that early. You should be able to tell if it is regular by looking to see whether the steering mechanisms are open and the gears are visible, which would mean it is a regular. Like someone else said, IHC always reused parts so you never know what you might find. Since it is such an early F20 you might have a duckbill which is a little more rare. The steering mechanism would clearly look like a ducks bill.
Today's Featured Article - Horsepower Defined - by Staff. Indicated Horsepower This represents the power developed in the enine cylinder as obtained from the pressure in the cylinders. This is pressure obtained from an indicator which shows cylinder pressures. Indicated horsepower does not represent the actual useful power delivered by the engine. Brake Horsepower This is the actual horse power delivered by the engine to the shaft. It is equal to the "indicated horsepower" less the friction of the engine. It is useful hor ... [Read Article]
