Re: 300U hydrualics issue-again
Posted by pete 23 on May 30, 2014 at 10:17:30 from (74.33.76.120):
In Reply to: 300U hydrualics issue-again posted by 300dave on May 30, 2014 at 06:57:53:
Whoa, running a pump with no oil. I hate to run them even a few minutes when they don't prime. Second, what condition is the ORFICE screen in the regulator valve assembly. That is the little jewel that passes the fluid through that tiny orfice to keep regulator piston down on ball keeping it open for low pressure standby. If insufficient fluid flows through the piston will move up, ball seats, system goes on pressure, the increase pressure forces more oil through the orfice and the piston again opens the ball, system goes back on low pressure standby. I usually, (not always) drilled them out a little as the newer orfices were larger. Went from .024 ti .031 but with wear in system I have gone over .040 on some.
