Re: 400 rear axle hub bolts
Posted by Janicholson on May 10, 2014 at 04:53:52 from (74.60.94.18):
In Reply to: 400 rear axle hub bolts posted by Fudd on May 09, 2014 at 19:32:41:
If you heat the heads of the bolts to red hot, then quench them with a hose, they will swell from the heat, be pliable enough to mold to the size of the rust, then when cool, shrink to an under size. This breaks the bond with the rust. using a impact wrench then rotates them and they come out. Jim
Today's Featured Article - Talk of the Town: Miracle Formula for a Stuck Engine - by Edited by Kim Pratt. Another great discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: I have a stuck 4 cylinder engine. Two pistons right at the top, other two down. From underneath everything looks good. Up top looks bad. Thanks in advance." ... [Read Article]
Latest Ad: Looking for a minneapolis moline zts [More Ads]
