Re: 656 fast hitch or 3 pt.?
Posted by Aces on January 21, 2014 at 08:48:14 from (64.5.67.237):
In Reply to: 656 fast hitch or 3 pt.? posted by pilot199 on January 20, 2014 at 17:59:44:
Pilot199! I don't see to good of an answer here, so see if this helps. First the fast hitch distance between the points is fixed, but they could be sprung from bad use. I don't know the measurement. You could find that out and maybe get it back to size would not be easy. Replacing with 3pt not bad job, if you can find every thing.
The picture will help. The fast hitch will have to come off including the sway stop that goes under the PTO, this will include the long link going up to the rockshaft arm. In front of the sway blocks on the tractor now is the torsion bar, the is where the 3pt rams go on. You will have to retime the rockshaft arms from fast hitch to 3pt. The third link above the PTO does not look just right so check that out to make sure. You do not have to do anything to the hyd. hitch levers it will just work the same. The rocker shaft and arms should be marked 3pt 2pt. You can't just go to a junk yard and buy a hitch and put it on a tractor with a hitch, because there is way more the just the hitch, would not have hyds would not have torsion bar below for draft. But you have that now. If you need more just ask!! good luck
Today's Featured Article - Talk of the Town: What's in Your Tractor's Toolbox? - by Staff. This recent discussion on the Tractor Talk discussion board here at the on-line magazine drew so much response and proved to be so interesting that we wanted to share it with you here. The names of the people participating in the discussion have been left out to "protect the innocent" (to quote a once-popular television series). ... [Read Article]
