Hook up the battery as it was when you purchaced it.If the ampmeter reads to discharge(engine running),and you are sure it is charging,swap cables.The electricty can go either way,it doesnt care...If it still reads discharge,Then you have a chargeing problem to figure out.Another way to determine correct polarity is to turn on the lights.Simply see what the amp gauge says.That can be remedyed by simply reverseing the wires on the amp gauge.As was said,it was 6v pos ground when new.However,alot can be changed after 50+ years....
Today's Featured Article - Tractor Traction - by Chris Pratt. Our first bout with traction problems came when cultivatin with our Massey-Harris Pony. Up till then, this tractor had been running a corn grinder and pulling a trailer. It had new unfilled rear tires and no wheel weights. The garden was already sprouting when we hooked up the mid-mount shovel cultivators to the Pony. The seed bed was soft enough that the rear end would spin and slowly work its way to the downhill side of the gardens slight incline. From this, we learned our lesson sinc
... [Read Article]
Latest Ad:
[More Ads]
