Posted by Janicholson on October 14, 2013 at 19:44:29 from (74.60.94.18):
In Reply to: Super H 12 volt system posted by mudlake Jim on October 14, 2013 at 19:00:54:
A Hitachi Alternator # 14231 is a nice small alternator that wires just like a Delco 10SI. The existing bracket can be turned upside down and threaded rod and nuts are used to space the alternator into belt alignment. The regulator is built in, so no worries. The big terminal stud is connected to the amp gauge with a #10 wire. It hooks to the amp gauge on the terminal not connected to the battery by way of the starter switch connection. The amp meter will need its terminals reversed so the charge rate is to charge side (right) of gauge. The battery should be connected with negative ground. The coil needs to be changed to a 12volt with no external resistor required, or it needs to have a chevy (mid 60s) ballast resistor put on the lead coming from the ignition switch. The coil should be wired so that the Positive terminal is connected to the ignition (or resistor) and the negative is connected to the distributor side terminal. (if it is a mag ignition, ignore the coil stuff above, no changes are needed or desirable) The L terminal on the alt is connected to, one of the following: a 3amp diode from radio shack with the band end of the diode toward the alternator, a marker lamp from a side marker light (not LED), or an LED with a 10ohm 5 watt resistor in parallel with it, the other terminal or connection to the above connects to the ignition voltage (at the ballast resistor on the switch side, or at the positive terminal of the 12v coil). These options are equal in usefullness. If you want an idiot light the bulb or LED and resistor will light up just like in a car when the ignition is on but the engine is stopped,or the alt fails. The S terminal on the alt connects to the Big terminal. it is a very short wire. The diode or light or LED keeps the engine from continuing to run when the igntion swithc is turned off. It prevents alternator voltage from supplying running current to the coil. If it is a mag ignition, the voltage to start it charging is still needed. A simple solution is to T into the oil pressure fitting at the block and put a oil pressure switch that is normally open closed on pressure (NAPA) into the T. This switch is connected to the L termtal on the alternator, and the other terminal is connected to the starter switch battery connection. The L terminal is equal to the #1 terminal on the Delco, and the S terminal is equal to the #2 terminal on the Delco. The reason for choosing the Hitachi is that the Delco is big and will just barely fit under the hood of an H. (no real belt adjustability) the Hitachi fits well. Jim
Today's Featured Article - Product Review: JB Weld - by Staff. JB Weld is basically an epoxy glue that does an exceptionally good job of bonding to cast iron and steel along with several other materials. As I mentioned, it is so common that I have yet to buy a tractor that did not have JB Weld used somewhere. It is sometimes used so well you can't tell its there and other times used as a sloppy quick fix. Finding where and how it can be used correctly is key to whether you are using it as an "inelegant hack" or an integral solution to difficult and expens
... [Read Article]
