Re: farmall A pto issue
Posted by old on September 27, 2013 at 09:58:31 from (209.86.226.58):
In Reply to: farmall A pto issue posted by barryb on September 27, 2013 at 08:56:47:
Hows it run with out engaging the PTO?? Will it pull it self just fine in all gear when PTO is not engaged?? If you answer yes time to pull the belt off and check the spindle or spindles on the belly mower and make sure they spin freely. Sound to me that you have a bad bearing or bearings on the mower that need to be replaced.
By the way not a good idea to throw parts at a problem before finding the problem or you can cause your self bigger problems
Today's Featured Article - Talk of the Town: What's The "Stuckest" You've Ever Been? - by Edited by Kim Pratt. Another great discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "I was about 14 (part of the problem) when I got stuck. I was disking with a cab equipped IH 966. The window was dirty and I was driving into the evening sun. It was hard to see and it was my first pass down the field. I got the tractor so stuck that the underside of the tractor was resting on the ground. My uncle wanted ... [Read Article]
Latest Ad: 65 Massey FERGUSON DIESEL [More Ads]
