Reverse polarity can mess up the VR and make her fail to charge properly, but that has nuttin to do with if a cutout relay is stuck closed causing a heavy discharge when shes not running
Today's Featured Article - Product Review: JB Weld - by Staff. JB Weld is basically an epoxy glue that does an exceptionally good job of bonding to cast iron and steel along with several other materials. As I mentioned, it is so common that I have yet to buy a tractor that did not have JB Weld used somewhere. It is sometimes used so well you can't tell its there and other times used as a sloppy quick fix. Finding where and how it can be used correctly is key to whether you are using it as an "inelegant hack" or an integral solution to difficult and expens
... [Read Article]
