Re: 6 volt system, trouble starting, Ammeter registers in neg.
Posted by John T on September 11, 2013 at 04:59:20 from (216.249.76.176):
In Reply to: 6 volt system, trouble starting, Ammeter registers in neg. posted by dusty grass on September 10, 2013 at 19:02:09:
AS is usual, I agree with Jim, with nothing on there shouldnt be any sparkies or sizzle or current draw when you connect the battery.
If it had an 8 volt battery I wonder if Billy Bob at one time messed with the Voltage Regulator (if it had one) and it could be bad.
I would remove or loosen the genny belt and see if the genny spins when you conenct the battery?? If so maybe the cutout relay is stuck closed which causes a huge curent draw discharging the battery quickly. If it spins but stops if you remove either the wire to BAT or GEN/ARM on the VR or Cutout Relay, the relay is stuck closed and bad.
Or perhaps if the current draw is not as heavy, say only a few amps versus 20 or more if the relay is stuck, theres some other minor higher resistance short in the wiring.
For a 6 volt system Id use 0 or even 00 Gauge battery n starter n ground cables.......If it has a VR (versus only a cutout relay) it may have a problem........You gotta find the cause of the current draw first
Jim posted my troubleshooting procedure but you gotta do some investigation before you worry about the charging system.......
John T
Today's Featured Article - Torque Wrenches - by Curtis Von Fange. When working with fasteners a torque wrench can play an important role in the correct assembly of critical equipment components. Lets examine in detail some of the reasons for using a torque wrench along with how to correctly use the variety of wrenches available. Applying the proper torque to a fastener accomplishes a number of tasks. First of all correct torque will hold the parts together. This may seem like a trite statement but � think about it for a second. Engineers have designed ... [Read Article]
