Re: 6 volt system, trouble starting, Ammeter registers in ne
Posted by oldtanker on September 10, 2013 at 22:05:19 from (66.228.255.116):
In Reply to: 6 volt system, trouble starting, Ammeter registers in neg. posted by dusty grass on September 10, 2013 at 19:02:09:
Dusty also important with 6 volt systems is the size of the battery cables. Turning a 6 volt starter requires more AMPs. That requires heavier cables. The smaller cables common on modern 12 volt systems just are not big enough to work correctly. They will get hot and start to break down. If you are not getting enough AMPs/voltage the starter will not spin fast enough to start the engine. Most often an 8 volt battery was used as a band aid to "fix" another problem. Now if you have problems like low compression you may have to go to a bigger batt like an 8 volt to start or may have to rebuild. If you follow the trouble shooting guide you got and it still fails to start do a compression test and see where it's at.
Rick
Today's Featured Article - Talk of the Town: What's The "Stuckest" You've Ever Been? - by Edited by Kim Pratt. Another great discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "I was about 14 (part of the problem) when I got stuck. I was disking with a cab equipped IH 966. The window was dirty and I was driving into the evening sun. It was hard to see and it was my first pass down the field. I got the tractor so stuck that the underside of the tractor was resting on the ground. My uncle wanted ... [Read Article]
Latest Ad: 65 Massey FERGUSON DIESEL [More Ads]
