Re: 400 axle housing leak
Posted by CNKS on June 26, 2013 at 17:07:03 from (216.144.104.128):
In Reply to: 400 axle housing leak posted by Fudd@work on June 26, 2013 at 16:41:33:
The gasket alone won't do you much good. You have to remove the wheel and the end piece which contains the seal. Of course replace the gasket also. Don't try to remove the wheel by yourself. I use an engine hoist (cherry picker) and remove the rim and tire, any weights and then the wheel. The 1st time I removed a wheel and tire the hoist tipped over, luckily I was on the opposite side. IF you mean the gasket between the tractor and the housing -- yes people have done that.
This post was edited by CNKS at 17:08:04 06/26/13.
Today's Featured Article - Talk of the Town: What's The "Stuckest" You've Ever Been? - by Edited by Kim Pratt. Another great discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "I was about 14 (part of the problem) when I got stuck. I was disking with a cab equipped IH 966. The window was dirty and I was driving into the evening sun. It was hard to see and it was my first pass down the field. I got the tractor so stuck that the underside of the tractor was resting on the ground. My uncle wanted ... [Read Article]
Latest Ad: 65 Massey FERGUSON DIESEL [More Ads]
