Re: Small V-8 in anything?
Posted by Brendon-KS on June 07, 2013 at 03:53:43 from (63.245.190.37):
In Reply to: Small V-8 in anything? posted by S.D.L. on June 06, 2013 at 22:25:22:
It's not quite what you asked but IH also built several "half V-8" 4-bangers. The Scout originally had a 152 cid engine (half of a V-304) and later this grew to a 196 (half a 392). The one cylinder bank was chopped off then the engine was partially "straightened up" in the chassis which left the oil pan setting at an angle. Virtually all the internal parts were common between the 4- and 8-cyl versions.
Today's Featured Article - The Nuts and Bolts of Fasteners - Part 2 - by Curtis Von Fange. In our previous article we discussed capscrews, bolts, and nuts along with their relative hardness and thread sizes. In this segment we will finish up on our fasteners and then work with ways to keep them from loosening up in the field. Capscrews, bolts and nuts are not the only means of holding two parts together. When dealing with thinner metals like sheet tin, a long bolt and ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
