Belt leaves front idler then to center bottom sheave left around front of left spindle back to middle sheave on the back side then around back side of right spindle around to the top sheave on center back to rear idler and around drive pulley. for right hand mower and like other post says you do have a right hand mower. There will be a twist in the belt coming back to rear idler. Your belt should be 225in long. Any B-225 belt will work. Your idlers are in the right position
Today's Featured Article - The Nuts and Bolts of Fasteners - Part 2 - by Curtis Von Fange. In our previous article we discussed capscrews, bolts, and nuts along with their relative hardness and thread sizes. In this segment we will finish up on our fasteners and then work with ways to keep them from loosening up in the field. Capscrews, bolts and nuts are not the only means of holding two parts together. When dealing with thinner metals like sheet tin, a long bolt and
... [Read Article]
