Re: F-20 crankshaft ball-bearings
Posted by Skaning on May 19, 2013 at 14:57:05 from (184.21.242.202):
In Reply to: F-20 crankshaft ball-bearings posted by EM Iowa on May 19, 2013 at 07:43:22:
The original bearings were "full complement" bearings meaning that they had a notch in the race so that all the balls possible could be loaded into them. There was no seperator between the balls. IH was confident enough that they put a lifetime warranty on them. Case doesn"t honor that today. The bearings are a standard size, but most that you find are not full complement. It means that the load capacity is less. Generally, if it"s just going to be a showpiece, it won"t make a lot of difference, they will work just fine. Going to put it back to work, consider finding the full complement replacement. I went through this om my regular when I had the engine done.
Today's Featured Article - Horsepower Defined - by Staff. Indicated Horsepower This represents the power developed in the enine cylinder as obtained from the pressure in the cylinders. This is pressure obtained from an indicator which shows cylinder pressures. Indicated horsepower does not represent the actual useful power delivered by the engine. Brake Horsepower This is the actual horse power delivered by the engine to the shaft. It is equal to the "indicated horsepower" less the friction of the engine. It is useful hor ... [Read Article]
