Re: 886 ta issues
Posted by Janicholson on May 18, 2013 at 09:57:42 from (74.60.94.18):
In Reply to: 886 ta issues posted by Jbraman on May 18, 2013 at 07:40:05:
Does it free wheel? If you were going 7mph on flat ground, and throttled down to idle, would the tractor slow down as the engine slows, or would it coast?
Is it in the lower set of speed range, or the higher (direct)?
Does the lever action make any difference in Feel or sound, and can you feel the detent in the lever motion?
Does the Orangish looking oil pressure light work? It operates on MCV pressure and should light when the clutch is pushed in (IIRC), and MCV pressure controls TA clutches.
We kind of need these answers to be accurate on our suggestions. Jim
There are some issues with the TA end of the cable that would be the easiest fix.
Today's Featured Article - History of the Cockshutt Tractor - by Danny Bowes (Dsl). The son of a very successful Toronto and Brantford, Ontario merchant, and himself quite an entreprenuer, James G. Cockshutt opened a business called the Brantford Plow Works in 1877. In 1882, the business was incorporated to become the Cockshutt Plow Company. Along with quality built equipment, expedious demand and expansion made Cockshutt Plow Works the leader in the tillage tools sector of the farm equipment industry by the 1920's. ... [Read Article]
