Re: farmall c generator
Posted by Don Mountain on April 15, 2013 at 09:25:32 from (184.5.199.73):
In Reply to: farmall c generator posted by burnsg2003 on April 14, 2013 at 18:16:27:
I had some similar problems on my Super C tractor. Ended up rewiring it to clean up bad connections and burnt wires and mouse chewed wires in the system. Then went through 3 regulators before buying one that worked properly. The Cheap, non-functioning new voltage regulators offered for sale from the Case/IH dealer can drive a person nuts trying to find out what is wrong elsewhere in the electrical system. So, check all of your wire connections, and recheck that your "new" voltage regulator is good.
Today's Featured Article - Horsepower Defined - by Staff. Indicated Horsepower This represents the power developed in the enine cylinder as obtained from the pressure in the cylinders. This is pressure obtained from an indicator which shows cylinder pressures. Indicated horsepower does not represent the actual useful power delivered by the engine. Brake Horsepower This is the actual horse power delivered by the engine to the shaft. It is equal to the "indicated horsepower" less the friction of the engine. It is useful hor ... [Read Article]
