Re: farmall c generator
Posted by Janicholson on April 14, 2013 at 19:46:53 from (74.60.94.18):
In Reply to: farmall c generator posted by burnsg2003 on April 14, 2013 at 18:16:27:
I agree to check the belt. If there is 7 to 7.2 volts across the battery terminals when running at 3/4 throttle all is well. that is a good charge rate. A properly operating VR will move the charge to near zero when fully charged. Jim
Today's Featured Article - Horsepower Defined - by Staff. Indicated Horsepower This represents the power developed in the enine cylinder as obtained from the pressure in the cylinders. This is pressure obtained from an indicator which shows cylinder pressures. Indicated horsepower does not represent the actual useful power delivered by the engine. Brake Horsepower This is the actual horse power delivered by the engine to the shaft. It is equal to the "indicated horsepower" less the friction of the engine. It is useful hor ... [Read Article]
