IHSMOKE, if you haven't already remove the float and submerge it in a pail of hot water for several minutes. If you have a hole in the float it will fill with water and you'll need to fix it or get a new one. Also, I've read on this forum that the black tipped needle jets are much better at sealing than the red ones.
I experienced the exact same issue you're having when trying to rebuild the carb on my Farmall 460 gasser this past winter. I make no claims as to my mechanical prowess, but I have rebuilt several automobile carbs of various brands in my life. I have never experienced the problems I did with that infernal thing. It would be difficult to find a more simple working device, yet after following the directions for float adjustment that came with the rebuild kit and in the shop manual I could not get it to stop free-flowing gas. I had seen an add in Red Power Mag for Denny's Carb Shop, so finally in my frustration I bit the bullet and sent the son of Satan off to them for a pro rebuild. When I got the carb back I bolted it on and the old gal fired right up and ran great. It was a little pricey ($265.00), but to me it was well worth the money. Denny's boiled it out of course, re-milled the mating surfaces and removed and pressed in all those new little brass pieces. All things I couldn't do due to a lack of the proper tools/machinery. A pro carb rebuild will be the only way I go from now on when it comes to old tractors.
Today's Featured Article - History of the Nuffield Tractor - by Anthony West. The Nuffield tractor story started in early 1945. The British government still reeling from the effects of the war on the economy, approached the Nuffield organization to see if they would design and build an "ALL NEW" British built wheeled tractor, suitable for both British and world farming.
... [Read Article]
