Re: F20 running badly
Posted by Secret Squirrel on March 09, 2013 at 17:11:15 from (70.194.136.84):
In Reply to: Re: F20 running badly posted by Andrew Psencik on March 09, 2013 at 16:40:28:
If it still has the original setup, original mag and all, the mag has a round cover on the rear of the mag, looking at it from the rear of the tractor. There is a hole in this cover that has a rod, connected to a longer rod that has a handle at the steering wheel post. Looking at the cover where the hole is, the cover rocks from 1:00 to 5:00 o"clock position. All the way up should kill the tractor, and keep it from starting. Move it down a bit until you feel a bump, and that is where you should start it. All the way down is maximum timing, or working position. You may have to run it at a different position for best preformance, depending on condition of mag, carb, etc. If you are hand cranking the tractor, the further down the mag is set, the greater chance of the crank kicking back.
Today's Featured Article - Talk of the Town: What's in Your Tractor's Toolbox? - by Staff. This recent discussion on the Tractor Talk discussion board here at the on-line magazine drew so much response and proved to be so interesting that we wanted to share it with you here. The names of the people participating in the discussion have been left out to "protect the innocent" (to quote a once-popular television series). ... [Read Article]
