Re: 706 jumps out of reverse
Posted by Baelee05 on February 09, 2013 at 05:25:25 from (12.192.13.220):
In Reply to: Re: 706 jumps out of reverse posted by RodHergott on February 08, 2013 at 20:44:01:
Don"t let what the Vet is telling you scare you. Everything he is telling you is true but if you start at the top and work your way through them it isn"t that difficult. You just need to buy the tractor priced accordingly because some of those linkages and shifter parts have gotten really spendy. Take the cowl around and on top of the dash off and take the platform cover between the fenders off and you can pretty much do everything.
Today's Featured Article - Measuring with Calipers - by Staff. The legs of inside calipers are curved outward at the extremities to facilitate measuring small holes, while outside caliper legs have a large curve inward to increase their capacity for large work. Firm-joint calipers are adjusted approximately by the hands and then set to the feel of the work by tapping them on a metal surface. It is a common practice when opening calipers by this means to tap the top of the joint. It is better, if possible, to tap the inside of the legs, as repeated blo ... [Read Article]
