Re: Ih460 wiring ,coil question
Posted by Janicholson on January 29, 2013 at 18:26:31 from (74.60.94.18):
In Reply to: Ih460 wiring ,coil question posted by LarryNMO on January 29, 2013 at 18:10:31:
A 6v coil or a coil designed to run with a resistor will be 2.5 to 3 ohms or so. A 12v coil will be more like 4 to 5 ohms. Jim
Today's Featured Article - Converting from 6 Volt to 12 Volt - by Chris Pratt. It's a common problem for old machines especially when the weather starts to dip below 40 and the tractor isn't fired up as often. You are probably used to the 12 volt Diehard, charged with 200 amp alternator of your 3/4 ton that always is ready and always starts. It's this type of experience that brings about the many queries we get for 12-volt conversion kits. Since only a few kits are available (we sell kits for the ... [Read Article]
