Re: SC Throttle Problem
Posted by mkirsch on January 22, 2013 at 06:47:06 from (64.80.110.74):
In Reply to: SC Throttle Problem posted by Bud W on January 21, 2013 at 07:28:21:
The governor housing will come off without touching the distributor or the drive gear. It's not very difficult, but you do need three different wrenches to get all the bolts out. Some need a deep well socket, some a shallow, and one or two will only come out with a box wrench.
Make sure you pay attention to which bolt comes from which hole.
The only reason to remove the gear and weights is if something is wrong with the weights.
Today's Featured Article - The Nuts and Bolts of Fasteners - Part 2 - by Curtis Von Fange. In our previous article we discussed capscrews, bolts, and nuts along with their relative hardness and thread sizes. In this segment we will finish up on our fasteners and then work with ways to keep them from loosening up in the field. Capscrews, bolts and nuts are not the only means of holding two parts together. When dealing with thinner metals like sheet tin, a long bolt and ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
