Re: SC Throttle Problem
Posted by gene bender on January 21, 2013 at 17:28:16 from (67.55.226.151):
In Reply to: Re: SC Throttle Problem posted by Bud W on January 21, 2013 at 11:07:31:
No you dont need to remove the dist. Just dont move the gear that drives it. Its not easy but it can be done ive done it many times. Get the new spring from IH for the A or B as they take the same. If theres no response from the throttle thats the problem. Check the bearings on the shaft they are in three parts its called a thrust bearing..
Today's Featured Article - History of the Nuffield Tractor - by Anthony West. The Nuffield tractor story started in early 1945. The British government still reeling from the effects of the war on the economy, approached the Nuffield organization to see if they would design and build an "ALL NEW" British built wheeled tractor, suitable for both British and world farming. ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
