When I have been inside the gov's on the A's, I have had to go though the front. Meaning you will need to pull the radiator, but you will be able to leave the distributor in place. The spring is in the gov housing. If you end up pulling the gov weight assembly out, watch the timing marks is all. While you are in there, check the bearing too.
Today's Featured Article - The Nuts and Bolts of Fasteners - Part 2 - by Curtis Von Fange. In our previous article we discussed capscrews, bolts, and nuts along with their relative hardness and thread sizes. In this segment we will finish up on our fasteners and then work with ways to keep them from loosening up in the field. Capscrews, bolts and nuts are not the only means of holding two parts together. When dealing with thinner metals like sheet tin, a long bolt and
... [Read Article]
