Posted by Yooper Farmall on January 01, 2013 at 08:24:44 from (68.61.187.168):
In Reply to: Wheel weights on H posted by David G on December 31, 2012 at 16:47:08:
Re: Wheel weights in reply to Old weldor, 09-27-2012 07:55:34
Re: Bolts for farmall h rear wheel weights in reply to TylerFarmallH, 05-07-2012 18:51:45 I put my wheel weights on Sunday afternoon, I put both weights on the land (left) side. The bolt specs were provided by FarmallHal, he got them from his Farmall IH Parts Catalog. For the first set bolted to the cast iron center: 3/4" x 4 3/4" NC machine bolts along with 3/4" lock washers and hex nuts.
For the second weight that bolts to the first weight: 3/4" x 3 3/4" NC machine bolts along with lock washers and hex nuts. washers should be 1 1/4" OD x 25/32" ID 10 gauge.
I ended up purchasing the bolts from fastenal.com, for the first set instead of 4 & 3/4 length I went with 5", for the second set instead of the 3 & 3/4" length I went with 4"
first set: http://www.fastenal.com/web/products/detail.ex?sku=20373 Fastenal part no 20373 �-10 x 5� plain finish square head bolt $4.42 each
second set: http://www.fastenal.com/web/products/detail.ex?sku=20369 Fastenal part no 20369 �-10 x4� plain finish square head bolt $3.65 each
I got lock washers and hex nuts from tractor supply as well as 1 1/4" machine bushings that I put behind the lock washers.
Each weight is 145 lbs, I lifted a weight to the cast iron center, lined up the holes and had my wife slip the top bolt in and finger tighten the nut. Then I was able to put in the other 3.
I used the method of 1st weight to wheel center and 2nd weight to 1st weight because I was lifting them by hand, but another method is getting longer bolts and connecting both weights with the 4 bolts instead of 8. Good luck.
Today's Featured Article - On the Road with Dave Gohl: Auction Musings - by Dave Gohl. I was thinking the other day about all the auctions I've been to in the last few years. There've been many. Some have been very good, some have been well, disappointing to say the least. But no matter how good or bad auctions may be, we always seem to stay until the item we've come for or are interested in is on the block. I've been to some auctions near and far. I think the furthest has been the Two Cylinder 7 in the Amana Colonies last year. Lots of stuff, lots of people. I've also atten
... [Read Article]
Latest Ad:
Late 50s early 60s international harvester 560 with cultivator
[More Ads]
