Re: Wheel weights on H
Posted by NoNewParts on January 01, 2013 at 04:34:59 from (67.240.145.25):
In Reply to: Wheel weights on H posted by David G on December 31, 2012 at 16:47:08:
like Janicholson said
I put mine on with a 4' steelworkers pry bar
wheel bolt hole at 12 o'clock
pick up the weight and hang it on the axle
pry bar thru a weight bolt hole
stand up with it (easy with the pry bars length)
stick the protruding pry bars point thru the
12 o'clock wheel bolt hole.
weight hangs on the prybar
slide the weight up tight on the prybar
put the other 3 bolts in
easy
Today's Featured Article - History of the Nuffield Tractor - by Anthony West. The Nuffield tractor story started in early 1945. The British government still reeling from the effects of the war on the economy, approached the Nuffield organization to see if they would design and build an "ALL NEW" British built wheeled tractor, suitable for both British and world farming. ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
