I have a NOS one that requires the pressure switch to sense oil pressure which starts the meter. That is the system IH used to run the meter with has an electrical motor. Mine is for a 6 volt Super C and I've thought of wiring it directly to the hot side of the ignition switch so it would run whenever the switch is in the on position since I don't have the pressure switch and they don't seam very easy to locate. Might be a little hard to find one which runs on 12 volt for your H though unless you can find something which were on the later 12 volt tractors, Hal.
Today's Featured Article - Engine Basics: Spark Plug Cleaning - by Staff. Cleaning procedures: Brush or blow dirt from around the spark plug base. Remove the plug with a correctly fitted wrench. Examine the porcelain insulator and points. If the insulator appears to be melted or blistered, cracked or broken, and the points seem unduly burned it is evident that the plug is operating too hot and it should be replaced with a colder plug. If the plug is fouled excessively with carbon it apparently is operating too cold and it should be replac
... [Read Article]
