Re: H brakes
Posted by wayne in mn on October 10, 2012 at 08:23:02 from (64.118.12.213):
In Reply to: H brakes posted by Grantl on October 09, 2012 at 18:48:15:
Likely you are referring to band style brakes. To adjust: apply the brakes fully, lock the pedal, set the adjusting screw on the bottom of the brake cover by turning it in until it touches the brake band then back out 1/2 turn and lock the set screw. This helps prevent the brake from dragging on the drum while driving.
Re-check your pedal free play and set to 1-1 1/2".
Drive the tractor and test the brakes to aee if they pull the tractor to one side or the other with the pedals locked together.
Today's Featured Article - 50 Tips for Ford N Owners - by Bruce Haynes. Over the years of owning these three tractors, I have managed to refresh what little mechanical knowledge I had and add a little more, thanks to the wisdom and helpfulness of many fellow N owners. So, now it's my turn to share a few of the tips I've picked up. ... [Read Article]
Latest Ad: Massey Ferguson model 65 diesel tractor [More Ads]
