Re: H brakes
Posted by Janicholson on October 09, 2012 at 20:41:15 from (96.24.99.126):
In Reply to: H brakes posted by Grantl on October 09, 2012 at 18:48:15:
If the total clearance inside with the adjuster loose is more than about .050" the housing needs to be machined (at the surface where it bolts to the frame) so that the clearance is about .030" if this is not done the adjustment will be used up, and the braking force will not be very good either.
Stack the expander and the disks together on the bench and use a good caliper to measure the thickness. The depth of the housing should be just more than this, (by the above amount.) The housing and friction surface on the tractor as well as the expander all wear as they are used. This size increase must be repaired when servicing the brakes when they get to the end of the adjustment, or before that. Jim
Today's Featured Article - The Day Mom Drove the 8N - by Brian Browning. My Dad was wanting to put in a garden but couldn't operate the 8N and handle the old horse drawn plow he had found and rigged up to use with the tractor. Well, he decided to go get Mom out of the house and have her drive the tractor while he walked behind the plow. You got to understand that while my Mom is a hard worker who will always help whenever she can... she had never operated farm machinery before that day. Dad got her out there, explained how the clutch was the same as in our o ... [Read Article]
