Re: OT Water line
Posted by Dean Olson on October 09, 2012 at 13:42:48 from (98.196.66.64):
In Reply to: OT Water line posted by Aaron halfmann on October 09, 2012 at 12:31:09:
I have run 1" schedule 40 PVC about 800' to 14 hose bibs and 6 zone valves irrigating orchards and vegetable gardens. Well pumps 19 gpm's at 40-60psi
Works great.
Irrigation is controlled to only run 1 zone at a time. I'm typically the only one using this system and only run 1 hose bib at a time. I have had 2 sprinklers, from hose bibs, going at the same time and if I tried the 3rd it's starts dropping the water pressure.
To give you a good opinion we need to know how much water you need, (gallons per minute), what your supply is, (pipe size, pressure in pounds per square foot and gallons per minute flow rate), and how far you need to run, (feet, yards, miles, etc.).
Today's Featured Article - Horsepower Defined - by Staff. Indicated Horsepower This represents the power developed in the enine cylinder as obtained from the pressure in the cylinders. This is pressure obtained from an indicator which shows cylinder pressures. Indicated horsepower does not represent the actual useful power delivered by the engine. Brake Horsepower This is the actual horse power delivered by the engine to the shaft. It is equal to the "indicated horsepower" less the friction of the engine. It is useful hor ... [Read Article]
