Re: crank c123
Posted by teddy52food on September 24, 2012 at 10:07:11 from (184.94.175.179):
In Reply to: crank c123 posted by tuckaway on September 24, 2012 at 06:54:10:
Check for a mouse nest around the flywheel or remove the main bearing caps. Maybe a bearing is starting to spin in the block.
Today's Featured Article - Two-Brush Generators - by Chris Pratt. Whether for product liability or because the aftermarket parts and labor business is lucrative, this concept is disturbingly prevalent. Fortunately when you step into your shop and make that jump 50 years back in time to work with your old tractor, this concept goes out the window. Even so, when it comes to the charging system, people quickly revert to this idea and start replacing the major components one at a time until it works. The reason you don't find any decals in your replacement set wit ... [Read Article]
Latest Ad: Massey Ferguson model 65 diesel tractor [More Ads]
