Forgot to add you will need to make a couple wiring mods. Unhook the ground wire off the side of the mag, and run the negative wire from the coil to it. Then run a hot wire from the battery to the positive side of the coil. That is providing you have a negative ground system, if it is positive ground then reverse what I said above.
Today's Featured Article - Tractor Traction - by Chris Pratt. Our first bout with traction problems came when cultivatin with our Massey-Harris Pony. Up till then, this tractor had been running a corn grinder and pulling a trailer. It had new unfilled rear tires and no wheel weights. The garden was already sprouting when we hooked up the mid-mount shovel cultivators to the Pony. The seed bed was soft enough that the rear end would spin and slowly work its way to the downhill side of the gardens slight incline. From this, we learned our lesson sinc
... [Read Article]
Latest Ad:
[More Ads]
