Re: Framal c Question
Posted by Andrew Z on July 10, 2012 at 11:41:19 from (71.233.255.29):
In Reply to: Framal c Question posted by cleddy on July 10, 2012 at 11:36:28:
1950 C. Could be two things, one is there carrier bearings are shot for the axle. Second the snap ring or bolt (could be either or on the C) has come off or loosed up allowing play. You can see the end of the axles though the PTO assembly when removed, or pull the top cover off.
Andrew
Today's Featured Article - My Ford Golden Jubilee - by Troy Estes. This article is about my '53 Ford Jubilee and a story that starts with taking the tractor to my brother's Starter/Alternator Rebuilding shop for a wiring fix. The generator was shot as well as all the wiring. I dropped off the tractor expecting a transformation from a 6 volt to a 12 volt system utilizing the original generator housing, and a total rewiring of the whole tractor. The front end center pin bushing was worn also so I ask that they replace it if they had time. Well, that�s wha ... [Read Article]
