Re: B 414 how to change 12 volt positive to 12 volt negative
Posted by Lewis Jackson on June 20, 2012 at 11:34:37 from (65.216.245.114):
In Reply to: B 414 how to change 12 volt positive to 12 volt negative posted by Lewis Jackson on June 20, 2012 at 08:09:06:
OK, If I leave it a positive ground system, will regular 12v lights work? And if I did need to jump start, just put the ground cable on the tractor positive and ground the hot cable? Also, can I use a standard 12 neg. ground battery charger to charge the battery?
Today's Featured Article - Talk of the Town: What's The "Stuckest" You've Ever Been? - by Edited by Kim Pratt. Another great discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "I was about 14 (part of the problem) when I got stuck. I was disking with a cab equipped IH 966. The window was dirty and I was driving into the evening sun. It was hard to see and it was my first pass down the field. I got the tractor so stuck that the underside of the tractor was resting on the ground. My uncle wanted ... [Read Article]
Latest Ad: 65 Massey FERGUSON DIESEL [More Ads]
