Re: Super M 50 yr old fluid
Posted by Haas on September 26, 2000 at 06:07:30 from (129.37.117.59):
In Reply to: Super M 50 yr old fluid posted by sam on September 25, 2000 at 18:10:23:
I use one of those plastic storage tubs you get at your local Home center to catch the transmission fluid. A 14 gallon one only costs about $5. That way you do not have to worry about sliding buckets while the fluid is running out.
Post A Followup
: Re: Re: Super M 50 yr old fluid
Today's Featured Article - Measuring with Calipers - by Staff. The legs of inside calipers are curved outward at the extremities to facilitate measuring small holes, while outside caliper legs have a large curve inward to increase their capacity for large work. Firm-joint calipers are adjusted approximately by the hands and then set to the feel of the work by tapping them on a metal surface. It is a common practice when opening calipers by this means to tap the top of the joint. It is better, if possible, to tap the inside of the legs, as repeated blo ... [Read Article]
