Re: B Head on Super C
Posted by gene bender on May 07, 2012 at 17:54:16 from (67.55.226.143):
In Reply to: B Head on Super C posted by DelMN on May 07, 2012 at 07:34:42:
It will bolt on but the compression chamber in the head mite be different. Put the two side by side and compare as they did change the design of the heads in the compression area. Bolt holes will be the same and the gasket will work if you have newer stepped pistons make sure they have clearence for the piston. If the C has flat top pistone there wont be any problem. You can set the head on the engine and use some modeling clay then turn the engine over and check the clay.
Today's Featured Article - Magic Moments - by Tyler J. Woods. Magic moments don’t just happen. You have to help them along. This morning, I got up early. It is my day off from my regular workweek and I had a lot of things to do. It’s fall, and with winter coming on, there is a lot of work to do before weather closes in. ... [Read Article]
