Re: farmall h oil
Posted by Mike1972chev on May 02, 2012 at 19:10:55 from (99.57.2.237):
In Reply to: farmall h oil posted by mj56 on May 02, 2012 at 18:08:50:
Make sure it is dripping out the top petcock !!!!!
Today's Featured Article - Measuring with Calipers - by Staff. The legs of inside calipers are curved outward at the extremities to facilitate measuring small holes, while outside caliper legs have a large curve inward to increase their capacity for large work. Firm-joint calipers are adjusted approximately by the hands and then set to the feel of the work by tapping them on a metal surface. It is a common practice when opening calipers by this means to tap the top of the joint. It is better, if possible, to tap the inside of the legs, as repeated blo ... [Read Article]
