Re: i-h scout engine running problem
Posted by Super-H-Mike on April 20, 2012 at 07:56:19 from (76.164.145.223):
In Reply to: i-h scout engine running problem posted by glennster on April 19, 2012 at 18:30:59:
Sounds like it is still the carb to me. What happens if you whiff a little carb cleaner in the throat when it is idling? Does it pick up (meaning its lean) or stumble(meaning it is rich) ? What happens when you cover the carb with your hand while idling? If it sucks hard and dies that is normal. If it picks up or races, its a vacuum leak somewhere. Also,I know you said the plugs are new, but I would try 4 new ones anyhow again. They can get fouled or coated from running bad and tinkering around with stuff trying to correct the problem. Dont just clean em, and even if they look fine, try new ones. Easy and cheap. I have learned that leason the hard way. It is especially true of low output ignitions and seemingly simple engines. I assume your gas is good, cuz you tried running it of a can.
