Re: H wide front end
Posted by athol carr on April 10, 2012 at 14:16:30 from (115.188.3.223):
In Reply to: H wide front end posted by Joe in CA on April 09, 2012 at 21:33:02:
third party image
The original IH wide front had two mounting options, either way out in front which meant a longer wheel-base and much greater turning circle but the side mount cultivators could be fitted in behind the axle or in a rear-mount position where the wheel-base was almost the same as the narrow front wheel-base giving a shorter tractor, a better turning circle but the side-mount implements would not fit. My grandfather had an M in 1945 to replace the 1939 M (narrow front as that was all that was available during the war) which had the wide front set in the short wheel-base position. My father said much easier for ploughing, just drop the front wheel in the furrow and the tractor steered itself. It was never used for row-crop work, just needed the long axles to work slightly more safely on the river terraces. It is probably me sitting on the tractor in 1945
Today's Featured Article - Talk of the Town: What's in Your Tractor's Toolbox? - by Staff. This recent discussion on the Tractor Talk discussion board here at the on-line magazine drew so much response and proved to be so interesting that we wanted to share it with you here. The names of the people participating in the discussion have been left out to "protect the innocent" (to quote a once-popular television series). ... [Read Article]
