Re: WD40
Posted by rustred on March 23, 2012 at 20:49:51 from (72.172.100.113):
In Reply to: Re: WD40 posted by 55 50 Ron on March 23, 2012 at 10:05:04:
the gas model, WA40 and WK40 had the 6 cyl. truck engine in it.
the rear rubber is 32" as it came from factory. the right front hub is original also but the left one was broken so i had to use a cut down steel with rubber for now till i find the real cast hub for it.
Today's Featured Article - Tractor Generators - by Chris Pratt. As a companion to the articles on three-brush and two-brush generators, it seemed fitting that we should provide our readers with a description of how a generator works in lay terms. The difficulty with all those "theory of operation" texts is that they border on principles of electricity or physics and such. Since I know nothing of either, you will have to put up with looking at the common sense side of how generators work which means we " ... [Read Article]
