Most VE pumps have no internal marks like VA did, and use lift dial gauge to set timing. You can also scribe a line on pump and timing cover if drive shaft has key for alignment, also check flywheel, may have marks there. Most VE pumps I see have lock timing.
Today's Featured Article - Measuring with Calipers - by Staff. The legs of inside calipers are curved outward at the extremities to facilitate measuring small holes, while outside caliper legs have a large curve inward to increase their capacity for large work. Firm-joint calipers are adjusted approximately by the hands and then set to the feel of the work by tapping them on a metal surface. It is a common practice when opening calipers by this means to tap the top of the joint. It is better, if possible, to tap the inside of the legs, as repeated blo
... [Read Article]
Latest Ad:
Late 50s early 60s international harvester 560 with cultivator
[More Ads]
