Re: Body Filler
Posted by CNKS on March 06, 2012 at 17:55:38 from (216.144.104.128):
In Reply to: Body Filler posted by Jim Paterson on March 06, 2012 at 17:25:58:
PPG DF 705, or equivalent, try to keep the thickness to no more than 1/8 inch, I try to get it to 1/16. In other words get the damaged area as flat as you can get it before application. 705 is best for bare metal. I sometimes cover it with one of the Evercoat products, or for a few pinholes a single stage putty. If putty sand it all off and just leave the filled pin holes. The most common and also the worst one you can buy is Bondo, leaves a lot of pin holes to fill.
Today's Featured Article - Talk of the Town: What's The "Stuckest" You've Ever Been? - by Edited by Kim Pratt. Another great discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "I was about 14 (part of the problem) when I got stuck. I was disking with a cab equipped IH 966. The window was dirty and I was driving into the evening sun. It was hard to see and it was my first pass down the field. I got the tractor so stuck that the underside of the tractor was resting on the ground. My uncle wanted ... [Read Article]
Latest Ad: 65 Massey FERGUSON DIESEL [More Ads]
