Re: Oil Reservoir Question
Posted by JRSutton on January 24, 2012 at 06:45:59 from (75.130.109.233):
In Reply to: Oil Reservoir Question posted by bordermen on January 24, 2012 at 05:37:29:
Practically none.
The A's use a suprisingly small amount of oil back there. Basically just enough for the bottoms of the transmission gears to touch
... wish I could remember the exact spec - but it's only about 5 quarts.
It's such a small amount it's worth just draining it and refilling just to be sure you've got the right amount.
Put too much in and it'll start dripping out past the seals (most likely -unless you put new ones on recently)
You can flush it with kerosene too while you're at it - drain it - put in a gallon or two of kerosene - drive around a bit - drain - then fill with gear oil.
I'm sure somebody here can tell you what the exact number of quarts you need.
Today's Featured Article - Talk of the Town: What's The "Stuckest" You've Ever Been? - by Edited by Kim Pratt. Another great discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "I was about 14 (part of the problem) when I got stuck. I was disking with a cab equipped IH 966. The window was dirty and I was driving into the evening sun. It was hard to see and it was my first pass down the field. I got the tractor so stuck that the underside of the tractor was resting on the ground. My uncle wanted ... [Read Article]
Latest Ad: 65 Massey FERGUSON DIESEL [More Ads]
