Re: cub oil pan is warped a bit
Posted by soundguy on January 09, 2012 at 09:29:18 from (107.41.118.3):
In Reply to: cub oil pan is warped a bit posted by moondoggie on January 08, 2012 at 20:22:21:
the bp hammer and wood will fix the hole that bent at the flange. I'd use washers to spread out the force when re-attaching. between that and a good gasket, she will likely straighten out when tightened down.
only other easy option is to fab up some wood or plate metal to the pan fore to aft and then tweat it a bit.. I think I'd let a thick cork gasket and washers do it though if it was me..
have seen someone take flat narrow and thin say.. 1/2" by 3/16" stock strips and drill em and put under bolts along oil pan flanges.. kind of like a strip washer.. etc..
soundguy
Today's Featured Article - Talk of the Town: Removin Broken Bolts - by Staff. Another great discussion from the Tool Talk Discussion Forum. The discussion started out with the following post: " How would I remove a bolt thats broken off in a piece of metal and I want to save the treads in the metal and then put in a new bolt. " ... [Read Article]
