Re: Super A Valve Clearance
Posted by Doug on September 04, 2000 at 06:02:47 from (63.27.255.31):
In Reply to: Super A Valve Clearance posted by Stan Scott on September 04, 2000 at 05:27:54:
This is only a guess, but you might try to set the cold clearance at about .020 then warm the engine and readjust to .014. Rule of thumb would be too loose instead of too thight. Good luck. Let us know what works. I am going to be rebuilding my A soon, and will need to do the same thing for the fresh engine.
Post A Followup
: Re: Re: Super A Valve Clearance
Today's Featured Article - Torque Wrenches - by Curtis Von Fange. When working with fasteners a torque wrench can play an important role in the correct assembly of critical equipment components. Lets examine in detail some of the reasons for using a torque wrench along with how to correctly use the variety of wrenches available. Applying the proper torque to a fastener accomplishes a number of tasks. First of all correct torque will hold the parts together. This may seem like a trite statement but � think about it for a second. Engineers have designed ... [Read Article]
Latest Ad: WANTED IH C200 gas engine — complete running motor Wanted complete used IH C200 gas engine in running condition for an International 574 gas tractor. My block has a hole in it and is dead, so a rebuild kit wont do it — need a whole running motor. The C200 also came in the 544 and 674 gas trac [More Ads]
