Posted by Jimb2 on October 23, 2011 at 07:38:40 from (174.115.9.174):
In Reply to: 574 loader question posted by Kevin Roberts on October 22, 2011 at 19:22:21:
Hi, the 574 has no frame rails from clutch housing to front axle housing, so to prevent excessive force on engine block, the better loader frames have frame rails that attach to mounting holes on clutch housing to holes in front axle housing.
Go to caseih.com, search parts 2250 in search box and the select 2250 CaseIH Front End Loader and expand Figure listing and select 2-14 and items 5 thru 13 are attachments for a 74,84,95 Series tractors.
If you google image of IH 684, you will find some pictures of a 684 with loader mounted. The 684 has same frame as your 574.
Today's Featured Article - Talk of the Town: What's The "Stuckest" You've Ever Been? - by Edited by Kim Pratt. Another great discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "I was about 14 (part of the problem) when I got stuck. I was disking with a cab equipped IH 966. The window was dirty and I was driving into the evening sun. It was hard to see and it was my first pass down the field. I got the tractor so stuck that the underside of the tractor was resting on the ground. My uncle wanted
... [Read Article]
