Posted by pete 23 on October 08, 2011 at 11:19:34 from (74.32.234.149):
In Reply to: 656 weak pto pressure posted by Yellott Canby on October 07, 2011 at 20:11:14:
Original 806 was set to 185 psi with little problem. Most 656's were hard to get to that point due to the type of linkage they used but I never saw one slip or cause problems at 165 psi. You could go to a heavier spring on the lower end of that valve(the spring that you need to take out that tiny pin to get apart) to get more pressure easier than redesigning the linkage. They changed the valve and springs on larger tractors to accomodate a lock nut and increase the pressure to 235psi . Don't remember if they did that to 656 or not. Many are set higher of course as personal preference. I always liked to see the pto slip before it tore the center section out of clutch backing plate myself.
Today's Featured Article - Product Review: JB Weld - by Staff. JB Weld is basically an epoxy glue that does an exceptionally good job of bonding to cast iron and steel along with several other materials. As I mentioned, it is so common that I have yet to buy a tractor that did not have JB Weld used somewhere. It is sometimes used so well you can't tell its there and other times used as a sloppy quick fix. Finding where and how it can be used correctly is key to whether you are using it as an "inelegant hack" or an integral solution to difficult and expens
... [Read Article]
Latest Ad:
WANTED Front grille/nose assembly for Massey Ferguson 1160 (also fits 1180 & 1190). Headlight-mount section. AGCO Grille 3706022M91 (supersedes 3705942M91), cover 3705494M1/M2, holders 3705501M91/3711158M92. New/NOS/good used OK. Jonesboro, AR - will pay shipping. Photo appreciated. Thanks
[More Ads]
