Re: 140 industrial steering wheel removal
Posted by Janicholson on September 24, 2011 at 17:19:01 from (67.72.98.45):
In Reply to: 140 industrial steering wheel removal posted by midmo on September 24, 2011 at 13:58:01:
They are way tough to remove (whole).
I would drill into the plastic, and use a cold chisel on the steel collar to try to swell it. Heat the shaft only, then let it cool (don't burn the plastic, hard to do! Jim
Today's Featured Article - Engine Valves - Some Helpful Information - by Staff. Intake - On the intake stroke the piston moves doward, sucking in carburized fuel through the open intake valve. Exhaust valve is closed. Compression - With both the intake and exhaust valves closed, the pistons upward stroke compresses or squeezes the fuel into the combustion chamber. Firing - Ignited by the spark, the compressed fuel explodes and forces the piston downward on its power stroke. Intake and exhaust valves are closed. Exhaust valves and seats are exp ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
