Re: 1940 h charging
Posted by Janicholson on September 24, 2011 at 12:40:30 from (67.72.98.47):
In Reply to: Re: 1940 h charging posted by David G on September 24, 2011 at 06:02:41:
With respect, sorry David, the generator's field is continually grounded with the light switch charge rate connection in this case. The field gets its supply voltage from a third brush in the gen, or if a two brush gen, it is from the Arm terminal connected to the non grounded brush.
The light switch has 4 positions LHDB in HDB positions the F terminal is grounded directly. In L the field is grounded through a resistor on the light switch.
I think this system is in need of a third brush adjustment, If moved closer to the fixed Arm brush, it should make more like 7 volts, to 7.2v.
John T has provided the guide to make it work.
Just educating, Jim
Today's Featured Article - A Farmall Restoration Story - What's Been Done So Far - by Sean Brinston. This is a story of my first real tractor restoration. My name is Sean Brinston and I was 15 almost 16 at the time of this.My neighbour directly across the road who I had helped with hay all the time had this tractor sitiing at his house for what I thought was 6 years. Finally I got the money and courage to ask him. I phoned him and he said it was already sold, eight years ago! ... [Read Article]
